I have a couple of questions to ask regarding a double row angular contact bearing that we are intending to use in a flat belt tensioner.
The bearing in question is a NSK 32BD219DUK. For reference the size is – 35mm x 55mm x 20mm and has a nominal internal clearance of 47 microns. Single piece outer & single inner & seals on both sides
The application for the bearing is to be used in a timing belt tensioner set up where a solid shaft will be press fitted into the inner race and a sleeve press fitted onto the outer race to bring the overall diameter up to 60mm. The bearing assembly will have a stationary inner race/ rotational outer that will apply tension to the back of a timing belt.
The question that I need to shed some light on is the clearance of the bearing regarding weather or not the bearing needs to be in a preloaded state or not. This can be adjusted by the amount of interference that the shaft and housing will produce. I have been told that angular contact bearings need to have a certain amount of preload to perform correctly. Is this correct?
The reason why I have to ask this question is that NSK produce a timing belt tensioner that has this bearing installed in a similar layout to the one that we are designing, and as they have no stock of the bearing at present, I obtained a number of these tensioner units to use the bearings as a stop gap. When checking the clearance of the NSK tensioners it was found that several units have a clearance of up to 20 microns and several others having zero. I can only presume that the tolerances of the bearing diameters and the shaft & housings that have been made are accumulating the manufacturing tolerances so that certain units had clearance and others had none – therefore putting the bearing into preload, hence my question regarding preload!
The other thing that will probably be a deciding factor is that the operating temperature will be approx 120 degrees C
Sorry for the long (1st) post! but would greatly appreciate any input on the above.
