milkshakelake
I’m concerned about using the kerf anchors in this nontraditional way, ¼” edge bearing, and moment caused from wind suction/push. The kerf anchors (1/4" plates/angles) will be attached with epoxy, which is normal, but I don't usually go into the depth of the stone; usually it goes into the edges. I’m not sure how the limestone will react to all this. Thoughts?
