My question is do anchor bolts have to be pretensioned before a moment is applied over the base plate?
A little more info on my project:
I am working on the structural support of a new stair that is being placed in an existing building. The stair is very fancy and very very heavy.
To make a long story short I am saw-cutting the existing slab to make way for a new footing for a column to support the required loads from the stair.
The column will be installed first and then the footing will follow. The footing and the finish slab will be completed as one unit. The anchor bolts will be furnished and will be in the base plate before the footing/slab is placed. The Base Plate as well as the anchor bolt nuts will not be exposed after the footing/slab unit concrete is fully cured. In other words the base plate with anchor bolts will be incased in the concrete. The concrete will be fully vibrated so the base plate will have fullt bearing once the concrete is cured. The anchor bolts will be tack welded to the base plate to insure they do not lift up during the placing of the concrete.
When everything is cured and ready to go moment will be applied over top placing some of the anchor bolts in tension from the moment. There is really no problem from the design stand point here accept that the anchor bolts will never have any pretension in them before the applied moment is applied over the base plate. Is this going to be a problem? If so, how so?
Thank you all,
Jeff
Thank you all,
Jeff
