Hi All
Regarding erection of one column(Dia=3700mm, overal length=35150mm) at site,I found a problem that the bolt extention beyond the nut(thread part)is not sufficient to consider another nut(luck nut).Contractor made 2 comments:first,using spot welding between nut and top plate(anchor chair),and the second, using another nut beneath top plate.
Its my pleasure to recieve your comments about these 2 mentioned items.
Thanks in advance
Thanks in advance
