analysis of a shaft
  • Thread starter Thread starter lance_lie
  • Start date Start date
L
lance_lie
Guest
I need help on constraining a shaft. One end is full constrained and theother end needs to be constained with a 14 degree displacement around the shaft axis to determine the stress caused by the twisting?
UP
how to allpy twisting load to shaft?
execuse me, I 'm novice.
I can apply force load to the model, but i can't apply moment and twisting load to model?
I really need help, I alread try thousands times!
Lance_lie
This can be done by using a total load at a point option if you are using solid elements. Since mechanica is a linear analysis you can apply a unit load measure how much it twist for the given load then scale the load and run the analysis again. For example lets assume that you run the analysis with a 1 in-lb torque and you get 2 degreess rotation (mechanica will give you radians but you could always convert) then in order to get 14 degress you will have to apply a 7 in-lb torque.
I hope this helps
Luis
There are many ways to apply a ywisting load to a shaft, I've been doing it since I was 13!!!! 8=>-_
