Analysis failure
  • Thread starter Thread starter rakic
  • Start date Start date
R
rakic
Guest
Does any body know how can I analyse my asembly.When I start the simulation , he said that some file is mising.
Must I have some specific file to do the simulation or not???
Edited by: rakic
Occasionally I forget to assign material properties, or loads, or constraints. I don't know if this produces a "missing file" message. You might check to make sure you have assigned these properites.
It maybe that one of the directories where Mechanica writes or read files is specified incorrectly. I don't use Mechanica often enough to know it well.These are just some ideas which may (or may not) help.
I know
I asign material , constrains , everything but it stil show me these warning.<IMG src="uploads/rakic/2007-01-31_123611_
Rakic, I am not an expert at this so my advice has limited value. But it appears your analysis has failed due to an error and this is why you can not display results. It does not appear that the analysis failied due to a missing file, but since the analysis did not complete due to an error, the results file is missing.
Do you see an error when you display thestatus as the analysis is running? I believe there is a file in the results directory with a .err extension which lists all the errors during the analysis.
Yes i see that error and hee stop analysis when the error ecured.
