cgrodzinski
I need your help on setting analogue outputs.
The output is +/-5Vdc. The units are absolute pressure.
If the pressure transducer is calibrated to gauge pressure 0-10bars and output settings are 500mV/bar and offset 1bar what voltage should be read at -5V, 0V, +5V.
I understand that the 0V = 1bar and +5V should read 11bars. What about -5Vdc=??
I appreciate your advice.
