Hello everyone
I've heard talk time and again from old mechanic types that various things will cause an engine to "suck a valve," and I've often wondered what they might mean when they say that, and whether there is any truth to the claims. Also I'm wondering what stories may have been true in the past and have since changed. Typical stories that I've heard:
"you shouldn't drive with a leaky manifold gasket, 'cause you'll suck a valve"
"you shouldn't install a muffler that flows too freely, 'cause..."
My questions to you:
* what (in your opinion) phenomena are referred to as "sucking a valve?"
* what are the commonly cited causes for these phenomena?
* how plausible do you think those theories sound?
* what (historical) engine configurations may have led to the modern tales about "sucking valves?"
My initial answers to the above:
"sucking a valve" could be:
1) valve breaks and parts fall into cylinder
2) valve comes loose and falls into cylinder
3) valve "tulips" and deforms such that it won't seat
the one "folk" explanation I've heard for 1 & 2:
"low pressure in the exhaust manifold allows cold (fresh) air in, resulting in thermal shock to the valve and fracture thereof"
Plausibility: I suppose that I can't rule this explanation out for the case where you have an extremely leaky manifold gasket (or valves exposed to fresh air), but it sounds like a completely implausible scenario for the "muffler that flows too well" case.
reasons why I think the above failures might happen:
1 & 2) corrosion of valve, broken retainer, etc.
3) excessive seating velocity (while hot) results in downward deformation of valve body
