Is there a possibility to use different amplitudes for the different shell section points, e.g. for applying different temperatures to the section points?
you have to use composite section in shell, divide the shell thickness (say 100mm) into parts (say 5 parts), hence u will have 5 x 20mm thick of shell, u could apply amplitude to the shell with different temperature.
