Dear Art Montemayor and tu1
1-You are right, I tink I did not explain may points, as clear as you discribed it. But when we are ,as chemical engineers, talking about symetrical arangement in piping, there should be a main aim that is same pressure drop which, we can easely get in symetrical piping.
2- For the elevation of the condensor, I did not see, in tu1 explanation about your point which is, ""both units condense vapor and drop out the resultant condensate directly by gravity into the NH3 receiver"". As long as we do not know the configuration, there is posibility to have reciver installed above condensor, as I have seen in many different plants. But you are right if we have condensors installed above the reciver,we do not need symetrical piping for condensor outlet.
3- Assuming condensors above reciver, with longer lenght piping from compressor to the second condensor, I think the load ratio (actual condensation capacity/design capacity) for the second condensor will be lower than the first one, but I foresee overally the problem of the system will be solved, Although the system arrengement is not an efficient one and condensors ar not in same load ratio.
thank you
