Paulo:
I believe quark has a valid point. This item may be important to your management and strengthen your position with them. You said you have peak refrigeration loads and also are expecting a lot of partial load situations. This, to me, is the crux of the application and I would expect that the design, specified basis for your screw machines would be the peak load amount. Any lesser (partial) loads would be attended to by a combination of the conventional slider valve (as mentioned by quark) and the subject VFD. Quark has done an admirable job in describing the variable capacity mechanical operation of the screw and I can add little except that the “turn-down” capacity control would be dependent on employing the slider, the VFD, or both. We don’t know how both systems would inter-act as designed by York – and this is an area of great concern (with good reason) as the operation applies to your load distribution. But quark rightfully expects to experience less “wear and tear” on the machines when they are working with a turn-down capacity using the VFD.
Your load distribution, I also believe, is the key to your projection of future cost savings – and justification to management for an investment in the VFD. Your ability to accurately describe and document it to management and to the proposed VFD supplier will not only lend confidence to management of your control of this project, it will also strengthen your position with the supplier since you have given him the added tools to accurately design and propose the correct and justified capacity control mechanism for your future machines. In the end, a successful project is one where the application works and BOTH the supplier and the user profit from it.
I agree with you totally that the most important role in managing and overseeing this future critical installation is that the choices and decisions you make now are the CORRECT ones for your application. This is very critical because, as you correctly state, you could wind up in a worse situation than before. It is constructive, in this type of project, for a young engineer to be cautious and study well his application before making an important decision that will have a large impact later on. The more information and data that you can supply your proposed or selected chiller designer, the better off you are with respect to negotiating a performance warranty or an understanding on what to expect. The refrigeration load distribution (as it relates to the expected capacity) is an important factor to lay on the table at the very outset. It should be in the interests of your supplier that you succeed in every goal that you have set forth in this application. And when he is given the opportunity to share in all your basic data, it strengthens his ability to carry out his best design.
I would also recommend that you insist on personally visiting similar, screw compressor refrigeration applications in the field that are operating with similar capacity variances and using VFD. I realize that management may frown on these costs, but I believe that you can rightfully point to this proposal as a direct means of obtaining captive information valuable towards a correct decision and contributing to company know-how in predicting and controlling future critical energy costs. Additionally, when you are reinforced with actual, field experience on the proposed application, a lot of the final decision to purchase and apply the VFD is shared with management – instead of being shouldered directly by you. This is always a good thing for you and your career: if the application fails, you don’t take 100% of the blame; if it succeeds, you make heroes of the management that worked directly with you. It’s almost a win-win situation. In my experience, you will find that companies like York will gladly cooperate with you in identifying similar, existing installations and work with you in visiting these. This type of experience can be a big boost in your learning curve and gives you the opportunity to learn first-hand the pros and cons of an actual VFD installation without the usual sales talk of supplier representatives.
I wish you luck in your application and congratulate you on achieving this big step forward in improving your present chiller application.
Respeitosamente
