flexoprinting
Hello Gentleman
Currently servicing an AMK az-40 drive system without current reading display. I would like to get an accurate amp reading to each of the four motors it supplies.
Using a Fluke i1010 current clamp is useless, it's Bandwidth rating is 10 KHz. The readings I'm getting are totaly unbeleivable, doing some googling it looks like
I need a probe with > 15 MHz Bandwith to accuarately asses each output. The expence of one is more than I can justify. I will be using a Fluke 8845 w/Fluke view
software to log my readings, so my questions are.
Considering the signal type, Can I use a current shunt to measure voltage across and calulate current accurately that way?
If so, would I need to put same value shunts on the other two phases as well during the test?![[ponder] [ponder] [ponder]](/data/assets/smilies/ponder.gif)
Chuck
Chuck
