drawoh
- Oct 1, 2002
- 8,960
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Ron247 said:Look at plumbing, can't reduce the diameter of a pipe in the direction of flow. How do you replace a section of damaged 8" pipe?
While lumber itself is easy to convert, the use of lumber is not easy. Try selling metric lumber when all remodels will require the old system. If you open up the first metric lumber mill, you better have deep pockets. Cabinets would no longer be 24"x36" as a standard.
dauwerda said:Of course I realize that - it wasn't my example. I was commenting on the fact that Canada seems to be figuring out how to deal with the "standard size" issue, so the US should be able to figure it out as well.
