AM module transforming Gcode to event series file format
mosta1
Hey,
Is there a way to transform the Gcode to inp file to be used in the AM module? I really need help. I'm totally lost in this matter.
There's only a script named "generateEventSeries.py". You can find it in the 3DSwym Simulia Community. But it's meant for use with g-code generated by the ReplicatorG software. In other cases, you would have to modify it, write your own script or use a spreadsheet do define event series.
