Apexpredetor
Good Evening All,
Quick question about Residential Code, Section %502.5(2) - Girder Spans and Header Spans For Interior Bearing Walls... Since I have a good depression on the side of my house I was thinking about making a garage under a prefab cape code type addition...
I am looking at some modular houses plans (continuing my escapade with home addition/garage). I keep seeing girder spans utilizing (4) 2x10's with spans over what, I interpret, is the maximum span of 6'-2" (supporting two floors, 28ft width).
I hope some of you are familiar with the trusses that come with modular construction? They are bolted together at the midspan. Maybe I am incorrect in assuming that these set-ups are supporting two floors since there is a pre-engineered roof truss supporting the second floor (Cape Code type modular addition) as clear span?
