Hey Guys,
I am trying to simplify a Calculation to get a Margin of Safety Calculation for an Aluminum sheet metal pull 'Thru' Calc to ensure enough fasteners are being used and the sheet metal is thick enough etc... I am taking a shot at this here so any suggestions would be greatly appreciated.
IN order to take worst case scenario I am using AL 5052 as my worst case analysis:
AL 5052 - Tensile U - 28KSI - (I pulled this value from a few material tables) is there a better value to use from MMPDS somewhere??
thickness - 0.032 inch
No. of Fasteners - 4
Fwd G load - 9G
weight of attachment - 13.6lbs total
So taking Pfwd load due to 9Gload:
Pfwd = 13.61lbs * 1.5 (FS) * 9G = 183.735 lbf
Ptf = P total force reaction load per fastener assuming all loads react equally.
Ptf = Pfwd / 4 = 45.93 lbf
Sheet Metal Pull-Out Area (assuming #10 washer area)
Circ. = Pi * 0.438 inch (diameter) = 1.376 inch
A = C * thickness of sheet metal = 1.376 * 0.032 = 0.044 in^2
Pull-Out Allowable = 28KSI * 0.044in^2 = 1232.9 lbs --> Which implies that a force of 1233# is required to pull this fastener through the sheet metal at 0.032inch thk... Does this seem a bit high??
Now I would like to calculate a MS for this as well and I am wondering what exactly to use for this:
- do I use the same method and calculate a lbf applied per fastener?
- using the Area of the washer head?
- or the area of the thickness of the sheet metal again?
i.e.:
A of washer head = pi/4 * D^2 = 0.1507 in^2
A of sheet metal (as before) = Pi * Diam * thk = Pi * .438 * .032 = 0.044 in^2
Stress = Pthr / A = 1232.9lbs / 0.1507 in^2 = 304.8 lbf
OR
Stress = 1232.9lbs / 0.044 in^2 = 1043.94 lbf
There fore MS = (Load Allowable / (Fapp * FS)) - 1
1) MS = (1232.9 / (304.8 * 1.5)) - 1 = +1.7 MS
2) MS = (1232.9 / (1043.94 * 1.5)) - 1 = - 0.21 MS
Any comments would be appreciated!
Fwd G load - 9G
i.e.:
OR
