DanvilleJeff
I have a several black plastic parts as part of a product that is placed in a large aluminum housing that is outdoors. The aluminum housing is painted on the outside, and the plastic is all exposed to the sun and weather. After several months, one particular plastic part becomes sort of "chalked over" with a loose film that is very reflective and looks white in the sun. The other plastic parts, made from a different material, are unaffected.
A chemist told me that the loose film is either aluminum or aluminum oxide from the environment that seems to stick to the surface of this particular plastic due to small fissures on the surface. Where could it be coming from? The aluminum sign should be covered in oxide that would be very stable I think. Does aluminum shed some amount of oxide in the outdoors?
Thank you,
Jeff
Thank you,
Jeff
