I have an aluminum jib track design that I need to find the maximum capacity for. If it was an I beam or a more standard track this would be simple but it is a patented enclosed track and I can't find any help on this subject. I have attached a PDF showing the design. Figure 1 just shows the boom set up, Figure 2 shows the track profile (highlighted in blue, black arrows show the load) and figure 3 shows the end plate on the end of the track. I believe the capacity is going to be limited by how much the bottom "flange" spreads open. Deflection is simple but could anyone point me in the right direction or tell me what to search for to calculate how much the part of the track the trolley rides on will separate or open up? In figure 2, I used the red arrows to try and show what I mean by separate. I know at the right and left ends of the boom in figure 1 will have zero separation and it will be at a maximum when the trolley is loaded at mid span but I don't even know where to begin to calculate this. Any help/direction would be much appreciated!
