JedClampett
- Aug 13, 2002
- 4,031
Our specifications prohibit the use of aluminum in non shrink grout. As far as I can tell, none of the major manufacturers use it and they're very clear in their data sheets that aluminum is not contained in their grout.
My question is: Was there a time when aluminum was commonly used in non shrink grout and why was it stopped? We have some corrosion at a grout steel interface and I'm wondering if a grout with aluminum in it caused the problem. The project was built in the very early 80's.
Is there something else that might be in grout that might cause corrosion? This is a common detail for us and I've never seen corrosion before, even on much older work. There was a case where there was a calcium chloride admixture added that corroded pre-stressing strands and caused a bridge collapse about 20 years ago, but I don't think using it was common.
