mufasa1
- Feb 27, 2002
- 45
Gentlemen,
API650 Appendix G - G.3.2 Aluminum Panels says as follows:
"Attachment fasteners shall not penetrate both the panel and the flange of the structural member."
Manufacturers are using either lapped joint or battened joint panel attachment system. At battened joint there is no penetration to the panel , where as on the lap joint there are many on the edges. On the other hand this changes the overall cost of the dome almost 30% (battened is the more expensive one)
Can we clearly say that lap joint panel attachment system does not conform with the code?
