I have an aluminum housing and am using stainless steel screws. After going through a 30 day salt fog test the aluminum housing was showing signs of corrosion. I had the white powder on the screw tested and the primary element indicated was aluminum. The aluminum alloy is 6061. I do not know the composition of the stainless screw.
In the same test chamber we had another aluminum body also with stainless hardware and there was no evidence of corrosion from the body to the screw. I do not know the composition of either the aluminum body or the screw.
My question is this: Is there a stainless alloy that will not permit the aluminum body to corrode? I suspected that the screw was cadmium plated but the lab that I had it tested at said that it was not plated. They said that its material characteristics were in line with that of a copper bearing austenitic stailless steel such as UNS30430.
One other question; What is the difference between an active stainless and a passive stainless if they presumably are of the same alloy?
Thank you.
Thank you.
