aluminium chassi
Moparigno
Automotive
Feb 2, 2012
3
I'm evaluating to build a front subframe using rectangular aluminium extrusions. I'm wondering if anybody did a similar work and have some suggestions/feedback to share.
I'm concerned about the suspension mounts. I would use stainless steel brackets to avoid corrosion, but I need to bolt them. My idea is to weld a small piece of aliminium tube through the rectangular extrusion and use it as a guide to pass the bolt through.
Any reccomendation ?
here is something similar on Audi R8 rear suspensions:
You may still get galvanic corrosion between stainless and aluminium and the bolt.
Is this just for a one off?
The big issue is softening of the HAZ .
Cheers
Greg Locock
