Statorwinder..............
Internal fan alternators actually draw the air in from the front and rear and, via the centrifugal fans, expel it through the stator windings. This is how they are cooled. The fan on the rear of the rotor often has more/larger blades, obviously biasing the air flow to the rear, to draw air over the Regulator/Rectifier assemblies, and push it out through the stator windings.
Some do however have bi-directional ("straight") fan blades, though only the French made Delco seems to use this method, at the rear. Does this help explain the relatively poor reliability of this unit, that regularly suffers terminal rectifier failure?
LordMalaK..............
Have you come across the increasingly specifed Water Cooled units, that cool via the engine coolant system? Complete with their lack of finning and with an integral water jacket? Normally these are fitted with one way, sprag clutch pulleys, not solid, that when they fail (and they do, with no predictability) do so "Large", sometimes taking the radiator too. Unfortunately they are increasingly being fitted to more mundane units. Yes I know the theory behind it...........
John.
"It's not always a case of learning more, but often of forgetting less"
