Alternate inorganic and/or organic coating for lead alloy [ballast plate]???
WKTaylor
Well-known member
Need your help with a very odd problem...
I have a ballast plate made from [gagggg... me] lead alloy [AMS7721 or AMS-L-18331]. Lead corrodes and obviously needs a corrosion protective finish.
The 'standard finish' [for decades] has been cadmium plate [AMS-QQ-P-416 Type II Class 2] or zinc-plate [ASTM B633] + post-plating chromate surface treatment + zinc-chromate primer + orange enamel topcoat.
Alternate finish was recently designated as zinc-nickel plate [AMS2417 Type 2] + post-plating chromate surface treatment + epoxy primer + orange epoxy topcoat.
Shop is 'balking' at all platings because: (a) cadmium is prohibited; (b) zinc is not available [on base] and zinc-nickel [bath] process is sensitive to contaminates that would 'spoil bath' for all other critical plating needs.
My first inclination is to enforce original cadmium or zinc plating + post plating chromate treatments by an 'outside' vendor...
However there is a 'side' of me trying to find 'work-around' base-platings, thus...
Apply...
(a) zinc or manganese phosphate treatment directly onto the etch, or grit-blast, cleaned lead surface + zinc-rich epoxy primer + colored topcoat...
or
(b) zinc-rich epoxy primer treatment directly onto the etch, or grit-blast, cleaned lead surface + colored epoxy topcoat...
or
(c) ???????????????
Please advise any unique and/or tried/true ideas for application of protective coatings to lead alloy.
Regards, Wil Taylor
o Trust - But Verify!
I assume this is for an aircraft application. Lead is very soft so I do not think any of the standard treatments would hold-up well in service. Scuba weights are often coated with PVC plastisol coating about 1/8" thick. It is applied by heating the weight and dipping in liquid plastisol, which congeals with heat.
Ditto on the plastisol- it's what I've seen used on lead weights which are frequently handled.
Will,
Is this a mass balance weight? In the past I have had success with a fine coat of epoxy resin and fiberglass cloth, where plating services were not available then polyurethane paint over the epoxy while the epoxy is still " Green" . Since most of your work is Military you may not have that option . But I will mention it for what it is worth.
B.E.
You are judged not by what you know, but by what you can do.
Berkshire... Yes this is a large/heavy flight control balance weight.
I decided on a course of action based on several comments... including a company that makes lead ballasts for boats/ships... and several coating experts who where also head scratching.
NOTE. Thick coatings described above are not usable on this ballast plate since it hast to fight tightly on a balance panel.
I am reluctant to 'cough-up' the actual process... right now... since I am unsure my shop can do the process... regardless I'll let everyone know what I 'finally dispositioned' AFTER the wet-tape tests.
Regards, Wil Taylor
