Alloy 20 Thermal Expansion
StressGuy
484
Alright, I've googled until my eyes bleed with no luck. I have an Alloy 20 duct system that I am specing out an expansion joint for. I cannot for the life of me find a reference on what the thermal expansion of this material is.
If someone in the group has a table, or a source for a table, I'd appreciate finding out what the rate is at 600 and 800°F
Thanks,
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
Looks like I finally tracked it down at the Carpenter Technology website
The setup is such that I can't make a direct link (frames, I think). From the main page, go to "Technical Information" over on the left side. Click on "Alloy Name Search" and put in 20. Alloy 20 will be the second result "20Cb-3 Stainless"
Enjoy,
--ED
Edward L. Klein
Houston, Texas
Hi Ed,
I have the following data from an old brochure for Carpter 20Cb-3 Stainless and it matches the data on their site.
77 F to 25 C to in x 10e-6/Deg F
212 100 8.16
572 300 8.62
662 350 8.71
752 400 8.76
842 450 8.84
Hope this helps.
Kevin
NozzleTwister
Houston, Texas
BTW, you need to register on the Carpenter website to access the data.
NozzleTwister
Houston, Texas
unclesyd,
I had that too but didn't post it since StressGuy only asked for 600F and 800F.
Confirm that you have a typo for 842F, the number should be 8.84 instead of 5.84.
I also have an old paper from Carpenter Technology dated 10/76 that has coefficients different from what they publish today.
NozzleTwister
Houston, Texas
I have one extra value from some very old literature.
77°F-212°F 8.16
77°F-842°F 8.54
77°F-1652°F 9.53
NozzleTwister,
I too have numbers that are slightly different If I recall correctly that there were two alloys at one period of time as I have some engineering data that says Alloy 20 and some from about the same time that says Alloy 20-3Cb.
