The designer can design the component only on the basis of the allowable stress for the material.The working stress will be much lower than the yield/max stress .I want to know the safety factor on yield/ Ultimate tensile stress.
All temperatures are ambient.
Rajan
Had to pull out my statics and strengths of materials book. What I found was
Allowable stress is the yield stress divided by factor of safety (for materials with elongation greater than 5%), with factors of safety range between 1.5 and 4.0.
When I worked on NASA contracts the factor of safety was dictated prior to any design (normally 1.5). I was told by an aircraft engineer their factor of safety for design was 1.25.
If you have test capabilities you may want to run some samples.
My understanding is rubber does not have an yield point/it is not reported in standard specs.Can we safely use 1/3 of UTS which is a guaranteed value as Minimum UTS by all rubber manufacturers?
Please advice
Thanks a million
Best regards
Rajan
You're right. I've always reported max. stress (ultimate stress) whenever I've tested elastomer samples. The curve (stress/strain or displacement) is linear. 1/3 of the ultimate would probably be a safe bet. I would rather design on the side of safe operation.
One other thing, if you have the capability to test the rubber it would be advisable to test a few samples and use the test data to determine ultimate stress. I'm not from Missouri, but I prefer to use test data over vendor's stated values.
