1503-44 -- I think that's a fair concern and it was only recently that I saw it to be a normal (or at least not unusual) assumption, for example in FHWA's example here (Step P.6), "Ultimate axial compressive resistance is determined in accordance with either equation 6.9.4.1-1 or 6.9.4.1-2. The selection of equation is based on the computation of l in equation 6.9.4.1-3 which accounts for buckling of unbraced sections. Since the pile will be fully embedded in soil, the unbraced length is zero and therefore l is zero. Based on this this, use equation 6.9.4.1-1 to calculate the nominal compressive resistance.":
Or in Bethlehem Steel's old H-Pile Manual where for a pile with "entire length embedded in any soil or combination of soils, other than virtually fluid material...the pile is supported throughout its length, and no reduction in load is required because of slenderness ratio." And so they end up a with a capacity based on a fully supported column. I think normally in the past when I've looked at stuff like this I've assumed an unbraced length based on soil-structure interaction results from something like LPILE or FB-Multipier using one of the many methods to determine a theoretical point of fixity, or assuming some depth to a point of fixity and finding the effective unbraced length using an assumed K between 1.2 and 2.1 depending on the pile head fixity.
PEinc -- right, if this were for new design definitely I would use the newest edition of the LRFD specifications. We're just being asked to evaluate these old existing H-piles using a service load/allowable stress methodology. I guess I was wondering if anyone had any insight as to the "why" of 0.25Fy (or 0.33Fy) for piles specifically.
For example, was it the case that engineers used to just find the pile reaction from simplified analysis (Pile Reaction = P/# piles + M*x/Iy_pilegroup + M*y/Ix_pilegroup) and they used a lower allowable stress because they weren't accounting for any soil-structure interaction or moment in the piles? In the "pile damage is unlikely" case where you can use 0.33Fy, it seems inconsistent that you'd allow such a low percentage of yield, where if you considered these piles as a typical compression element, the allowable stress would be a function of 0.55Fy and the slenderness ratio, which will probably result in an allowable closer to 0.55Fy than 0.33Fy. So I was thinking the 0.25 (or 0.33) allowable may've been some way to conveniently account for those kind of effects, or to sort of guide the engineer toward choosing a pile that wouldn't have issues during driving.
