I assist high-end home builders with various structural engineering issues. A common feature locally in high-end single family dwellings are garages with large basements below. The garage floor system is 8" precast plank with a 4" sloped concrete topping. On particularly large garages, a steel beam is needed to support the prestress plank spans. What is the allowable Dead and Dead + Live deflection criteria for this steel beam? I know for supporting concrete or masonry block, a more conservative L/600 is used. Does that apply here?
Attached is a sketch from the prestressed supplier to illustrate.
