Alistair_Heaton
- Nov 4, 2018
- 9,820
From what I can tell the FAA didn't actually know or realise what MCAS actually did or the effects of a failure in the big system picture to the normal operations.
The certifiers had white washed its effects or failure modes.
The trim window was special from a certification POV. If the NG had been certified less than a month later than it was then it couldn't have been certified.
The real killer for the trained pilot should have been able to cope was actually put to rest by a series of sim sessions in at the time in one of only two world wide simulators that was a MAX simulator. Everyone else only had access to NG simulators which were deemed sufficient due to the certification paper work put in to the FAA about training etc.
The FAA ran I think it was 12 737 experienced 737 NG pilots through it with a MCAS event.
The pilots were 6 from FAA system and 2 from EASA and the rest from other pilot geographical groups.
It was very quickly put under zero information disclosure rules.
By all accounts it really wasn't pretty with no real link between training backgrounds. That's where these percentages of less than 50% of normal line pilots started being quoted.
The real killer was when the FAA director at the time who was a very experienced 737 driver from classics through to NG and as a check airman was getting so much conflicting opinion he went and did it himself.
Literally with in minutes of him coming out of the sim the tone and process of the FAA completely changed into the hardcore that is seen today on the subject. And has continued since he left the role.
Again it was completely locked down from a public disclosure POV.
Most of us are pretty sure he crashed and burned in a quite spectacular fashion.
There are still people that have the POV that it was purely a pilot incompetency issue but I haven't seen anyone in the power circles even mention it since the grounding. In fact by far the bulk of the "chat" has been the NG should have never have been certified. And half the MAX problems are linked to its certification and the major changes rule.
