3DDave
Aerospace
- May 23, 2013
- 11,258
"Southwest Airlines Pilot Association" " A runaway stabilizer has continuous un-commanded movement of the tail"
Already dealt with. All trim runaway stops when the jack screw hits the stops, therefore there cannot ever be runaway because the movement is not continuous, per this definition.
"MCAS disables the control column response that 737 pilots have grown accustomed to "
That response is intermittent. As soon as force is relieved the trim will run again.
Anyway, it's a legal complaint, not an engineering or other assessment. It's goal is to convince uneducated people on a jury, not present truth.
"The EASA certification document referred to simulations whereby the electric thumb switches were ineffective to properly trim the MAX under certain conditions."
Always good to leave out what problem they are talking about.
"Also reading the wiki I hadn't realised that the screw jack was slipping due to the control force in both accidents."
What "wiki" claims the "screw jack was slipping"?
The wiki on ET-302 notes that, for a plane that had an Emergency AD, they thought a pilot with only 207 hours on type was thought a suitable choice.
