TugboatEng
Marine/Ocean
- Nov 1, 2015
- 11,976
I will be purchasing a new marine gen set soon and it is going to have J1939 can bus. I would like to tie it into my ancient alarm panel that requires relay inputs so I don't have to use pressure and temp switches. The engine will have J1939, Rs485, and eternet out. I need 3 relay outputs. So far I can find none that have an actual relay output, just sourcing and sinking. I know I can use that to switch relays but I'm looking for a single component solution.
