Nov 11, 2008 #1 sammyty Industrial Joined Jun 28, 2007 Messages 7 Location US Does anyone have a chart or quick reference on the corrosion resistance between al6xn and hastelloy c-276.? in a citric acid environment to be specific
Nov 11, 2008 #2 Unotec Chemical Joined Jun 13, 2006 Messages 593 Location CA Why not use 316SS? <<A good friend will bail you out of jail, but a true friend will be sitting beside you saying ” Damn that was fun!” - Unknown>> Upvote 0 Downvote
Nov 11, 2008 Thread starter #3 sammyty Industrial Joined Jun 28, 2007 Messages 7 Location US I wish....not an option Upvote 0 Downvote
Nov 11, 2008 #4 Unotec Chemical Joined Jun 13, 2006 Messages 593 Location CA Best I can do for you is: http://www.coleparmer.com/techinfo/chemcomp.asp but you probably need tables at different concentrations and temperatures, which this will not give you <<A good friend will bail you out of jail, but a true friend will be sitting beside you saying ” Damn that was fun!” - Unknown>> Upvote 0 Downvote
Nov 11, 2008 #5 EdStainless Materials Joined May 20, 2004 Messages 16,373 Location Waukesha WI USA Outokumpu shows a 6%Mo alloy suitable clear to 70% boiling. Unless you have a lot of Cl contamination 6XN should work fine. = = = = = = = = = = = = = = = = = = = = Plymouth Tube Upvote 0 Downvote
Nov 12, 2008 #6 strider6 Materials Joined May 4, 2007 Messages 616 Location IT I've found these data for C276 on Nace Corsur Database: C276 citric acid conc 5–60% temp °F 25–225 corrosion rate <2mpy this article on SS can be useful: Selection of stainless steels for handling citric acid (C3H4OH(COOH)3) http://www.bssa.org.uk/topics.php?article=28 S Corrosion Prevention & Corrosion Control Upvote 0 Downvote
