Thanks for your comments UcfSe
I think it's important not to forget that ASD has a long history of providing safe and economical structures. Also, many beams are governed by deflection criteria, not strength. The fact remains that members sized by LRFD are not much different from ASD, and I also learned in a graduate level steel course that the LRFD has been "tuned" so that it is not that much different in the member sizes that result. I am not a proponent of using the computer for all my design calcs. True, it can be faster, and some really tedious and monotonous equations are well suited for solution by computer. However, I have seen too many engineers who have relied too much on the computer, and their judgement has suffered as a result.
I disagree that leaving "E" as a variable doesn't really add to the complexity. The AISC manual should be a design manual, not a text book. The derivation should be handled in the commentary, and where the equations come from can also be seen in text books. I learned the theory of steel design with textbooks in college at the undergrad and graduate level. Someone who has not learned the theory of steel design using textbooks should not be using the manual to design steel structures.
With that said, I am trying not to have a knee-jerk reaction against LRFD. I have no problem with a more accurate approach. My concerns relate to the user-friendliness of the method. I also question if the supposed increase in accuracy is worth the extra effort for run of the mill buildings, considering the successful history of ASD. Still,I can see where the industry is headed, and I will make the plunge to avoid becoming "technologically obsolete". I think that the Unified ASD/LRFD Manual that AISC is putting together is a step in the right direction. I have no philosophical problem with finding the nominal strength of a member, dividing by a factor of safety, and then comparing that to the working loads. I will finish with this quotation from someone very wise:
structural engineering is the art of molding materials we do not really understand, into shapes we cannot really analyze, so as to withstand forces we cannot really measure, in such a way that the public does not really suspect.
