bookowski
- Aug 29, 2010
- 983
I'm looking at a cruciform column made up of four equal leg angles (4x4), 3/8" space between each angle, and want to make sure I'm understanding a few of the E6 (13th edition) provisions:
- Lower bound on fastener spacing such that kl/r of each shape < KL/r of the overall, easy enough
- Fasteners must also resist the shear transfer between parts. got it.
- Here's the part i'm not clear on "at the ends of built up compression members bearing on base plates all components in contact with one another shall be connected by a weld having a length not less than the maximum width of the member or by bolts spaced longitudinally not more than four diameters apart for a distance equal to 1-1/2 times the maximum width of the member". The "components in contact with one another"... since I have 3/8 spacers between my angles, I strictly read this as not applying since my components are not in contact. But if the intent is some minimum robust end shear transfer then it should apply I guess. The commentary states "in both cases the end connection must be welded or fully tensioned bolted", which would seem to imply that I do need them. If I assume that this does apply, despite not being in contact, and assume 3/4" bolts then I need end bolts @3" o.c. over a distance of 1.5 x 8 = 12", so say 4 end bolts on each cruciform leg top and bottom (so 32 bolts per column added). I've got loads of these so it's quite an uptick in fab/labor to add on 32 bolts per column if I don't need to. I have not run the numbers yet but I'm guessing that these end bolts far exceed what I need to transfer shear stresses in my column pure/mostly axial condition so it seems like a bit of a kick in the nuts to have to provide this. The commentary does note that the requirements "cannot be stated in terms of calculated stress but are based upon judgement and experience", I guess an acknowledgement that this may not make sense but do it anyway. (?)
