I am performing a structural analysis for an existing structure. This structure contains elements that does not fullfill the requirements set in Equation F13-2 of AISC 360-5/10. The section (vertical column) is a HE140A profile reinforced using a big strip with a cross-section 40x400mm.
Now I can not find any background information about Equation F13-2. I wonder what the concerns are when a member does not fullfill the requirements stated in this Equation? As the member is compact and we could prevent lateral torsion buckling if necessary.
Thanks for your help!
