Given a correctly formatted table of point info.
Your sketch needs a csys, and a short spline, select the spline, rt click and choose modify, in the control panel you have the choice to read in the point file and associated it with the sketch's csys. x is alway right and y up, so create the sketch oriented as needed.
You can explicitly define the end slope of the splines by an angular dimension at the end of each spline. Lets see. You need something else to dimension to, like a centerline. Pick the spline, crtl click the end of the spline, ctrl click the centerline, middle click to place the dimension.
BUT... Those tables generally have far more points than proe needs for good control of the spline. Judicious removal of points from the table can make the spline smoother, easier to adjust.
Depending on one's technique, it can be advantageous to have the top and bottom of the airfoil as separate curve features.
oh, and think the ends have to be dimensioned/constrained but it's been a long time since I did it for real.
Edited by: gkbeer
