Good morning,
I hope you're doing well.
I am working on a project to replace a 24 m section of a damaged 12'' pipeline. this pipeline is buried and transports diesel. The point to be repaired is located 14 m from a shut-off valve. the other valve is located 30 km from the first. remember that the pipeline is 250 km long and that the repaired point is 154 km from the head station.
. the profile is quite uneven (see diagram). I evaluated the ka volume recovered (around 200 m3). My problem is getting it back into service. due to drainage, there will necessarily be air trapped at different high points of the profile which can seriously disrupt operations (pressure pulsation and possible excessive suppression in the event of a shutdown). here are my questions:
1- my emptying procedure consists of making a tap at the damaged point then sucking the product into tanks. Do you have any suggestions or ideas for a better procedure because I want to minimize the drain volume and therefore the air intake.
2- I thought about using scrapers at a good position to reduce the flow of liquid to be drained. however I am thinking of the risk of ignition (air + fuel vapor+ friction) due to the scraper if it ends up in the section where the air is trapped. Are my fears justified, there are other easy ways to implement to resolve this pb.
What do you think?
pipeline characteristics
-ID: 11.75"
Length: 250km
leak point: 154 km
nearest bblock vavle 151km and 181km
profile see file attached of section between block valve. Repairs point in yelow.
What do you think?
-ID: 11.75"
Length: 250km
leak point: 154 km
