ERIMechEng
- Sep 22, 2009
- 20
Problem: I have a 20"x16"x7" box with some heat generating radio components inside. The aluminum box is sealed for EMI concerns, but the lack of heat exchange is causing the internal air temperature of the box to get too high, and the components are overheating and failing. As a modification, we installed EMI fan vents, which will allow some air to flow in and out, while keeping the EMI shielding intact. We installed some computer fans on the underside of the EMI vents to induce some air flow, but these are obviously not designed to "suck" air through something akin to an air filter.
Question: do "they" make any low profile fans that are designed to suck air through a filter? Mounting provisions are variable, though right now I'm working with an 80mm bolt hole square (size 6 screws). The reverse is do they make any fans that are designed to push air through a filter, or are conventional computer-type fans the best I'm going to find out there?
