Air Permeation Through Polymer Slab- Calculations?
nodalDOF
100
Here is a simple permeation problem I am trying to solve but confused with the calculations
Let’s say I have a cubical Glass vacuum chamber (volume V) with initial high vacuum about 10-5 torr. (No more pumping to maintain this constant)
The chamber has a rectangular seal of area 'A' on one of its sides which is exposed to atmosphere.
I would like to calculate the reduction in vacuum pressure with time because of air permeation through seal alone.
I know the permeability coefficients of each of the species in air. The question I have is about the pressure difference in the following equation.
According to the hand book of polymers, Permeate leak amount (of any species in CC),
Qi= Pi x t x A x (P_Out - P_In)/L
where,
Pi - Permeability Coefficient of N2,O2,Ar, etc ( in cm3-cm/cm2-sec-Pa)
t – time increment in seconds
A – Seal Area (exposed to air)
P_Out – atmospheric pressure? ( or is it partial pressure of each species in air)
P_in – instantaneous vacuum pressure ( again is this the total vacuum or partial pressure of each gas inside the chamber?)
L - Seal thickness
Currently I am using the atmospheric pressure (101325Pa) for P_Out and using the instantaneous vacuum pressure for P_in, but multiplying the diffrerence (P_Out-P_In) with the volume fraction of each species as follows.
For a small time increment of dt, Q_N2 = P_N2 x dt x A x (P_Out - P_In) x 0.78/L
Q_Air (in CC)= Q_N2 + Q_O2 + Q_Ar + Q_CO2 +....
Also, once I get Q_Air, I am calculating the reduction in vacuum assuming Air obeys Ideal Gas Law under vacuum:
P_reduction = nRT/V where n=Q_Air/22400 , R-Gas cont, T-ambient Temp in K, V-chamber vol
Am I doing it correct or it's not this simple? Any help is greatly appreciated.
Thanks,
Nodal
