Air leak rate conversion
bonll
13
how do I convert 0.0027 cubic inch p/second to psi p/second?
help please.
appreciate it thanks
b
errr I keep getting pulled off this to do other things sorry.
n = 293*.0001782(Vm3) / 8.314*293.13
The part is communication amplifier device (is sealed but hermitically).
n = 29356629*.0001782(Vm3) / 8.314*293.13
Meant to say...
"part (is NOT sealed hermitically). Not that it matters.... been a long day..
rb1957... I follow you on the atm, psig etc... but maybe im tired
I don't see how you derived at P = 56629 ?
Thanks for help by the way.
Ptest-Patm = 157953.7674-101325 ... i think it's right (like i said it's been a while)
thinking about it further i think i should've used the absolute pressure ... then n = 157964*0.000178/(8.314*293) = 0.01154 ... harumph ... your number ... oops !
hi rb1957
question, why wouldn't Ptest not be 160603.6Pa ?
'cause you said it was 157953.7674 (i calc'd it'd be 160603 Pa for 8.2psig)
and using it gave the "n" you quoted
rb1957 looking at it another way... (as in a bubble of 0.0027in3 p/sec)
Converting: .00027 cubic inch into Psi - using Ideal Gas Law. All constant variables reduced.
P1V1 = P2V2
P2=P1V1/V2 = ((23.3) (1in3))/((.9973 in3)) - knowns (14.7+8.6 absolute pressure)
P2 = 23.36 psi - calculate variable
ΔP = 23.36 – 23.3 - subtract initial pressure to get ΔP after 1 second.
ΔP = 0.063 psi / sec
rb1957 so am I crazy??? or does this look right (ΔP = 0.063 psi / sec) to you?
P1V1=P2V2 in this case doesn't work because you're not changing the volume, only the pressure and the mass of air in your fixed volume.
The V in this case is your fixed volume of the chamber.
you need to use the PV=nRT route.
I've done it again using 10 seconds worth to eliminate a few of the errors, but still come out with 0.0037 psi/second for your 0.0027 in^3/second
The volumes and pressure here seem minute and so I'm not surprised you're getting some strange answers
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
agreed ... you can't equate the laekage with the original condition.
determining how much air is in the leakage is easy nL = P(VL)/RT, P = 1 atm, V = leakage, T = 293
then return to your original PV = nRT with n = n(original)-nL.
i do wonder how this question is being asked. a leakage meter is going to measure the pressure decay, isn't it ? it won't readily let you the laekage volume rate, would it ? the most sense i can up to the question is the meter tells you one (pressure drop or volume rate) and you've got a client spec that expresses itself with the other ?
i guess the volume leakage is directly proportional to the psig insde the tank, so that as the tank pressure falls the leakage becomes less, asymptoting to 0 as the psig approaches 0 ?
I have tried to follow this thread as I some times need to evaluate the leakage rate for a generator gas space,which I see as the same test bonll is trying to perform, but on a much smaller scale. between the mixing of units, etc. I have been lost completely. Unfortuantely I am currently in such a hectic state I am also having trouble deriving the bases for the equations I have used for years so I just started with them and applied to this situation.
So to add to the confussion I have attached my thinking
 http://files.engineering.com/getfile.aspx?folder=6a28d7ef-2fdd-4e94-af73-2cc5c7f93668&file=air_test.pdf
That's nice, but I'm a bit disappointed that you didn't use Mathcad's built-in units. That would avoid some of the unit conversion shenanigan you employed to convert the problem. Can you post the actual worksheet?
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
I never got where I liked mathcad. the version I have is 4.0 and the generator air test sheet was something I used long time ago. the equations are actually published in the t/g manual. I did not save the changes I made for this situation to my original file. attached is that first equation with a couple more for determining H2 equivalant and correcting if test done at reduce pressure. the varables used are where I wanted to show if the test duration was just 1 hour, what thier expected error could be
 http://files.engineering.com/getfile.aspx?folder=a6b8828a-d4ee-45e5-8460-7698db56c22c&file=airtest.mcd
