air flow from multiple outlets
Ali768
Nuclear
GB
Hi
I have air coming in from a tank (one inlet) and going out from two outlets.
The inlet has flowmeter metering Sm3/hr with actual P,T also defined. I also have another flow meter metering at one of the outlets giving me actual flowrate (also P,T) but i dont have any meter on the second outlet neither know the P, T. How can I calculate the flowrate from the this second outlet. I am confused i did some calculations but i am nt confident.
Any suggestions/help will be appreciated.
Aly
Convert the inlet (I) and outlet (O1) flow you know to a molar flow rate. PV = nRT Then, if there is no reaction, O2 = I - O1.
Good luck,
Latexman
Instead of the difference in molar flow rates, you can calculate the difference in mass flow rates.
Thanks Latexman & Chicopee
I have calculated the all mass flow rates ........ now i want to calculate the volume flowrate of O2.
the P,T values are known at inlet and at one of the 2 outlets i.e O1.without P,T at O2 how to find volume flowrate at O2.
any idea or rough estimation?
Aly
Ali768,
Without T and P at O2, you cannot find the volumetric flow rate at O2.
Any idea? Measure T and P at O2, or if you know how much heat is transfered and what the pressure drop is for the air on the way to O2, estimate T and P.
Good luck,
Latexman
Since you know the chemical formula of air,calculate the %molar values of the components and multiply each % value to the air pressure to calculate the partial pressures of the components including oxygen (O2).
sorry did not understand your recent post........
(I) is the inlet, O1 is the first outlet and O2 is the second outlet. With massflowrates, O2 = I - O1.
P,T at inlet and at O1 is known, the two (I and O1) are at about 12 meters from each other where as O2 is at about 38m from (I).
whose last post?
Good luck,
Latexman
