I have 2 pellet lines utilizing dense phase positive-pressure conveying systems. Both lines have the same conveying distance.
Line 1:
Products: 95% are surface lubricated
Conveying line geometry: after exiting from RV, the 4" pipeline travels horizontally for 10 metres before making a vertical upward 90deg turn (approx 1m radius)
An approx plan view is below: "O" means out of paper
(RV)xxxxxxO
Air flow rate: 100 m3/hr to maintain conveying pressure of about 1 bar at the air supply side
Line 2:
Products: 50% are surface lubricated
Conveying line geometry: after exiting from RV, the 4" pipeline travels horizontally for 8 metres, then makes a horizontal 90deg turn (approx 1m radius), then travels approx 30cm before making a vertical upward 90deg turn (approx 1m radius). The downstream thereafter is the same as Line 1.
(RV)xxxx
x
x
x
x
O
Air flow rate: 150~200 m3/hr to maintain conveying pressure of about 1 bar at the air supply
My question is: Given the same pellet loading, why does Line 2 need more air flow than Line 1?
I'm trying to rationalize along the factors of
a) Product mix (only 50% surface lubricated in Line 2)
b) Conveying line geometry.
Is this correct and/or are there any other factors that I should look into?
Many thanks.
Line 1:
(RV)xxxxxxO
Line 2:
(RV)xxxx
x
x
x
x
O
Many thanks.
