Alph
Petroleum
- Dec 2, 2003
- 26
I have been asked a question by a colleague, it has left me unsure how to answer it.
A vertical cylinder type suction pile(ID=5m, L=6m), enclosed at the top, bottom is open ended (like a upside down bucket. It is lowered onto the seabed (water depth of 450m)at 2 m/s. The top of the the cylinder has a 600mm vent.
Q. At what depth will all the air be displaced or will all the air have been displaced by the time it reaches the 450m seabed depth ?
My thougts:-
At 2 m/s, it will take 225s to reach seabed. Volume of Cylinder is approx 118m³. Therefore Average air discharge is 0.52m³/s.
Assuming small dp of 0.1 bar across the vent and back calculating flow for the given orifice size. If the calculated flow is greater than than 0.52m³/s, then cylinder will be mainly be air free by the time it reaches the seabed.
Is there a more accurate/ detailed approach which can be used to answer the above question.
Al
My thougts:-
Al
