"Every" is a really tough concept for me.
I had an application once that needed to slowly ramp pressure from the low setpoint to the high setpoint. Working with the compressor manufacturer and several control valve manufacturers we all determined that the best way to do it was to not have an air receiver and let the compressor build pressure to match increasing resistance--worked great, and the control's solution with a receiver was going to require a PLC and a bunch of custom programming. I admit that this was a really odd situation that hasn't been repeated in 30 years, but it was a real requirement.
Engineers need to keep an open mind for simple solutions that step outside the box a bit.
David
