Agitator for Tank
fuady
ID
I have some problem to calculate the agitating system on my tank. I already known if the agitator position on top of tank, but I didn't know if it position on side of tank. How to calculate motor power req'd, size of shaft and everything that relation with the agitating system.
Who will help me to solve my problem?
Fuady
The makers of the agitators usually have all the sizing charts/programs needed to do this.
Thank's for your rbcoulter comment's. Can you give me information where I can find that charts/programs?
May be you can give me web site or title of books that explain it.
thanks
Fuady
Motor power is simple, just back it out of your velocity gradient.
BobPE
Thank's for BobPe suggestion's. From my reference that If we will design the agitating system, we have to use a spesific chart/graphic for each agitating type. I already have some charts/graphics for agitating system that have position on top not on side of tank. So if I use chart for top agitating system, the value of motor power and diameter of blade is impossible.
Maybe you have some another suggestion to solve this problem.
Fuady
Fuady:
Why is it impossible? I think I am missing something, could you provide us more information. What is the tank you are mixing a CFSTR or somethng else?
BobPE
Thanks for BobPE. The description for my problems is :
I will design agitating system on insulation storage tank with demension ID 3400 mm and 5400 height. The tank have 2.5" pipe steam heater on 300 mm elevation from bottom plate. It use saturated steam with 7 bar pressure. The agitator will be located on side of tank. Fluid content is Recover Oil. Temperature input content 43 degree celcius, Specifig Gravity 0.9, Viscocity 9 cP. The creteria the system is the content shall be reach 70 degree celcius on a half of tank capacity on 8 hours operation.
I will be appreciated for your help.
Fuady
Plenty mixers have a good letrature on side entry mixers,they can provide you with required charts.
Shahin71
Maybe I can pick up on something else in his post. Is the 2.5-in pipe heat exchanger direct injection heating or indirect? 7-bar sounds high to me for a heating application. Can anybody comment?
Carl
you are right 50psi pressure steam is enough,but we have to know the complete specifications of this particular case
I downloaded the spreadsheet noted by MJCronin from Sharpe and found that it apparently does not consider viscosity in the Hosepower calculation. I changed the viscosity values from 1 to 1000000 and it did not change the horsepower.
Be careful!
Thanks for all of your comment's. I am agree with trihydrate that spreadsheet from Sharpe is not correct. I had check from another reference that the some calculation on spreadsheet is not correct.
For leelaphani & isofuncurves, I appreciated for your comments, but if both of you are doubt about the pressure, it make me confussed. Becuase my design referred from the same tank on site, but my tank have more capacity 10 m3 from existing. The existing tank never get problem almost 5 years. The steam heating pressure on the existing tank is 6-7 bars. So maybe you have any comments for this?
For Shahin71, If you don't mind, can show me where I can get the charts or diagrams for that case. I really need it to solve my problem.
Fuady
Fuady,
Agitation and fluid motion is a very complex subject. There is a lot of publication about it, and respected companys investing in research & development. NJIT ( has some very good publications. There are also computer programs to do projects on agitators, including calculation of the shaft; type and position of impellers, power, speed, etc... Is easier than do all by hand. ( ( ( ( You have good sources of research here.
