Has anyone experience of aerated suction conditions and how one removes the air so that it does not affect pump capacity. The installation is a sea water intake where the suction line is approximately 50m long. At low tide where choppy conditions exist air entrainment affects the pump capacity. This is not described as air coming out of solution but a quantity of air entrained by wave action.
Because the suction conditions will be negative at close to the pump a conventinal air release valve is not seen as the solution. Some have suggest the need for vacuum pump to eliminate the air. I have thought of bleeding the discharge through an ejector and using this to pull a vacuum on the suction at the impeller eye.
Your ideas, particularly those put into practice successfully, would be most welcome.
