I've earlier posted some threads about gyros. Finally I can concentrate on this.
I use a gyro from Nec Tokin and managed to set up this circuit:
The gyro gives (when still) a signal at app. 1.3[V] and in motion +- 0.3[V]. First the signal goest through a HP filter with a large tau-time (this is necesarry in order to keep the voltage level at constant velocities). After the HP filter, I low-pass filter it with a gain of app. 39 times. Now i have a BP filter with a gain of 39times. Ive also added an anti-aliasing filter of butterworth type.
Now to the question. Is my solution the optimal one? Ive used basic knowledge in electronics and filters but hesitate if its correct?? Is this the right way to handle with gyros (and this types of sensors)??
The application Im going to implement this is to detect a lowspeed velocity (thats why I amplified it so much). Its very important that the voltage level is constant at a certain velocity. When the gyro is still (not moving) I want a zero-level at 1.5[V] (vref in the circuit). Hope u understand my problem...(dont hesitate to ask if wondered...)
