jonathanwilkins
I have to calculate a beam that has been notched on the tension face more than the building code allows. I'm reading the NDS and I think I'm on the right track but would like a little help.
Section 3.4.3 talks about shear design and goes into evaluating notches. They use a term..."adjusted design shear." Is this the maximum allowable shear applied to the beam? All other analysis uses shear stresses, etc. but this formula has no term for any applied load, shear, etc.
I do believe this is (Vr') the max allowable shear in the beam. Thanks.
