i would like to know if this is possible to build: planetary,heical, 15 degree taper internal ring gear about 6" dia. it will have (3) 1 1/2" planet gears equal spaced. i want these 3 gears to adjust in and out to change the diameter of the bolt circle dia. of the three while they are revoling. this will be done with a servo and ball screw.
