Hi Everyone,
In API 6A, for chokes section, there is a clause for "Adjustable chokes indicating mechanism". as per the clause, whenever the chokes supplied with manual hand wheel actuator,
---quote---
chokes should be equipped with visible orifice-area-indicating mechanism to define the orifice area at any adjusted choke setting throughout its operating range. This mechanism shall be calibrated to indicate diameters of circular orifices having areas equivalent to the minimum flow areas at any adjustable choke setting. These markings shall be in diametrical increments of either 0.4 mm {1/64".} or 0.8 mm(1/32".) for choke settings between 0.0 mm (0 in.) and 19.2 mm (3/4".). inclusive. For choke settings above 19.2 mm (3/4"), diametrical increments of 0.4 mm (1/64".), o.8 mm 1/32".), or 1.6 mm (1/16') may be used.
---unquote---
questions:
1. what is the visible orifice indicating mechanism and how it should design?
2. should we indicate the calculated the orifice area or the circular dia. of the orifice area in the travel plate?
3. What is meant by the diametrical incremental?
4. how we can design the indicating mechanism? can anyone suggest to understand more...
Dinu...
There are no secrets to success. It is the result of preparation, hard work, and learning from failure.
---quote---
---unquote---
questions:
Dinu...
